Ana içeriğe geç
Nikon D80 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon D80 Motherboard Replacement, Main Board: adım 1, 2 resimden 1. Nikon D80 Motherboard Replacement, Main Board: adım 1, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Motherboard Replacement: adım 2, 3 resimden 1. Nikon D80 Motherboard Replacement: adım 2, 3 resimden 2. Nikon D80 Motherboard Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Motherboard Replacement: adım 3, 3 resimden 1. Nikon D80 Motherboard Replacement: adım 3, 3 resimden 2. Nikon D80 Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Motherboard Replacement: adım 4, 2 resimden 1. Nikon D80 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Motherboard Replacement: adım 6, 3 resimden 1. Nikon D80 Motherboard Replacement: adım 6, 3 resimden 2. Nikon D80 Motherboard Replacement: adım 6, 3 resimden 3.
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
  7. Nikon D80 Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Nikon D80 Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Nikon D80 Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver.
    • Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws.
    • Gently remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sara Martin
586 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 41
Her zaman: 3,527
