Ana içeriğe geç
Ninja Mega Kitchen System BL770 Button Replacement
Neye ihtiyacın var
  1. Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: adım 1, 2 resimden 1. Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: adım 1, 2 resimden 2.
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Button Replacement: adım 2, 1 resimden 1.
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Button Replacement: adım 3, 3 resimden 1. Ninja Mega Kitchen System BL770 Button Replacement: adım 3, 3 resimden 2. Ninja Mega Kitchen System BL770 Button Replacement: adım 3, 3 resimden 3.
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Button Replacement: adım 4, 1 resimden 1.
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Button Replacement, Button: adım 5, 2 resimden 1. Ninja Mega Kitchen System BL770 Button Replacement, Button: adım 5, 2 resimden 2.
    • Locate which button you wish to replace.
    • On the back of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
Sonuç
Bir başkası bu kılavuzu tamamladı.
4 Yorum
Hi! I changed the “power button” and when I plugged it back, it went on without the press of the button, and it didn’t work. Think I may have made a lousy soldering job… :/
Luis - Yanıt
Got a dead BL780. Pretty sure it’s the power switch as it’s been harder and harder to push to turn on. Going to attempt to replace on the board. I’m guessing that it’s a tactile momentary switch and that the board controls the power activation instead of the tactile switch being a push on/push off. Any insight would be appreciated.
Mark - Yanıt
Where can I purchase the power button?
Mark
Cenek Picka - Yanıt
Where can buy switch? What part number is the switch?
Mountain Buoy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 2,089
