Ana içeriğe geç
Nintendo 2DS Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Nintendo 2DS Wi-Fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the 2DS.
  2. Nintendo 2DS Wi-Fi Card Replacement: adım 2, 3 resimden 1. Nintendo 2DS Wi-Fi Card Replacement: adım 2, 3 resimden 2. Nintendo 2DS Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Remove the game cartridge, SD card and stylus if your console has them inserted.
  3. Nintendo 2DS Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Undo the 2 Phillips #00 screws.
    • The screws will not completely detach from the battery cover.
  4. Nintendo 2DS Wi-Fi Card Replacement: adım 4, 2 resimden 1. Nintendo 2DS Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Lift the battery cover up and pull it out.
  5. Nintendo 2DS Wi-Fi Card Replacement: adım 5, 2 resimden 1. Nintendo 2DS Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Lift up the battery and remove it.
  6. Nintendo 2DS Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 1 resimden 1.
    • Remove the 10 Phillips #00 screws.
  7. Nintendo 2DS Wi-Fi Card Replacement: adım 7, 1 resimden 1.
    • Carefully remove the rear panel.
    • There's a ribbon cable on the rear panel attached to the motherboard, so be very careful not to damage that cable!
  8. Nintendo 2DS Wi-Fi Card Replacement: adım 8, 1 resimden 1.
    • Pull up the Wi-Fi card from the left side.
  9. Nintendo 2DS Wi-Fi Card Replacement: adım 9, 1 resimden 1.
    • Use a spudger or your fingernail to carefully pull up on the right side of Wi-Fi card. This'll disconnect the Wi-Fi card.
    • There's a cable behind the Wi-Fi card, so be very careful removing it!
  10. Nintendo 2DS Wi-Fi Card Replacement: adım 10, 1 resimden 1.
    • Flip over the Wi-Fi card.
  11. Nintendo 2DS Wi-Fi Card Replacement: adım 11, 1 resimden 1.
    • Use a spudger or your fingernail to remove the cable from the Wi-Fi card.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ella
2.221 İtibar
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where is the guide for the 2DS Zelda version? I just opened mine up, and there IS NOT a wifi module card anywhere to be seen?! Did they move it UNDER the motherboard? I can not find any guides to the green and brown Zelda 2DS. Mine won’t update or connect to anything now.
Jeremy Patton - Yanıt
It is the same. If you cannot see a Wi-Fi card, there probably is no Wi-Fi card.
Ella -
The wifi chip linked is a "2878D-J27H02301" but the one shown in the picture for the 2DS is a "DWM-W082", will either work or do I need to get a DWM-W082?
NullImmer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 40
Son 30 gün: 171
Her zaman: 5,193
