Ana içeriğe geç
Nintendo 3DS Wi-Fi Board Replacement
Neye ihtiyacın var
  1. Nintendo 3DS Wi-Fi Board Replacement, Loosen the rear screws: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo 3DS Wi-Fi Board Replacement, Remove the rear cover: adım 2, 2 resimden 1. Nintendo 3DS Wi-Fi Board Replacement, Remove the rear cover: adım 2, 2 resimden 2.
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo 3DS Wi-Fi Board Replacement, Battery: adım 3, 3 resimden 1. Nintendo 3DS Wi-Fi Board Replacement, Battery: adım 3, 3 resimden 2. Nintendo 3DS Wi-Fi Board Replacement, Battery: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo 3DS Wi-Fi Board Replacement, Lower Case: adım 4, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo 3DS Wi-Fi Board Replacement: adım 5, 3 resimden 1. Nintendo 3DS Wi-Fi Board Replacement: adım 5, 3 resimden 2. Nintendo 3DS Wi-Fi Board Replacement: adım 5, 3 resimden 3.
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo 3DS Wi-Fi Board Replacement, Wi-Fi Board: adım 6, 2 resimden 1. Nintendo 3DS Wi-Fi Board Replacement, Wi-Fi Board: adım 6, 2 resimden 2.
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo 3DS Wi-Fi Board Replacement: adım 7, 2 resimden 1. Nintendo 3DS Wi-Fi Board Replacement: adım 7, 2 resimden 2.
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the 3DS.
    FixBot'a Sor
    Yorum Ekle
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
David Hodson
156.367 İtibar
127 adet Kılavuz yazıldı
8Kılavuz Yorumları
I know someone who needs to have the wifi card removed from their DS for multiple reasons. If these steps are followed and the card is just removed will the 3DS still work to play games? They want to use it to play games only and do not want access to the internet.
brwnsrule - Yanıt Paylaş
Did this job, but the wireless is still not working. Any suggestions?
tech man - Yanıt Paylaş
Get a new wi-fi card. That is the only thing I have found to work.
afdflol82 - Yanıt Paylaş
will a 3ds xl wireless card fit within a 3ds? I am on Ebay looking to buy a replacement part but i can't find a proper replacement.
Daniel Garcia - Yanıt Paylaş
Hi David, i know this is an older guide, but you just saved me from buying a new 3DS. The wifi board had come lose in a drop, with your help i managed to reattach it and bring it back into working condition.
Thank you!
Michael Friis - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 140
Son 30 gün: 634
Her zaman: 60,918
