Ana içeriğe geç
Nintendo 64 Controller D-Pad Replacement
Neye ihtiyacın var
  1. Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: adım 1, 3 resimden 1. Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: adım 1, 3 resimden 2. Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the seven 10 mm screws from the body.
    • Remove the two 6 mm Phillips #0 screws from the expansion slot.
    • Separate the back cover from the front and set it aside.
  2. Nintendo 64 Controller D-Pad Replacement: adım 2, 2 resimden 1. Nintendo 64 Controller D-Pad Replacement: adım 2, 2 resimden 2.
    • Remove the left and right shoulder triggers by sliding them straight up.
    • Gently unhook the cable that is looped around two cable clamps by nudging it up and out.
  3. Nintendo 64 Controller D-Pad Replacement: adım 3, 3 resimden 1. Nintendo 64 Controller D-Pad Replacement: adım 3, 3 resimden 2. Nintendo 64 Controller D-Pad Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the three silver 6 mm screws holding the joystick assembly in place.
    • Gently lift the motherboard and joystick assembly out of the controller.
    • In order to avoid damage to the board, lift it by the edges.
  4. Nintendo 64 Controller D-Pad Replacement: adım 4, 3 resimden 1. Nintendo 64 Controller D-Pad Replacement: adım 4, 3 resimden 2. Nintendo 64 Controller D-Pad Replacement: adım 4, 3 resimden 3.
    • Slide the rubber pad off that covers the back of the D-pad.
    • Remove the broken D-pad from its socket.
  5. Nintendo 64 Controller D-Pad Replacement: adım 5, 3 resimden 1. Nintendo 64 Controller D-Pad Replacement: adım 5, 3 resimden 2. Nintendo 64 Controller D-Pad Replacement: adım 5, 3 resimden 3.
    • Insert the replacement D-pad into the socket.
    • Stretch the rubber backing onto the plastic pieces and slide it down over the D-pad.
    • Carefully reinsert the circuit board into the controller housing.
    • Insert the joystick into its opening.
  6. Nintendo 64 Controller D-Pad Replacement: adım 6, 3 resimden 1. Nintendo 64 Controller D-Pad Replacement: adım 6, 3 resimden 2. Nintendo 64 Controller D-Pad Replacement: adım 6, 3 resimden 3.
    • Carefully secure the cord around the cable clamps.
    • Be sure to apply enough pressure so it sits below or flush to the edge to avoid problems putting the front and back case together.
    • Re-insert the shoulder triggers into place.
    • The L trigger will go on the right and the R trigger on the left.
    • Use a Phillips #0 screwdriver to secure the screws to the joystick assembly.
  7. Nintendo 64 Controller D-Pad Replacement: adım 7, 2 resimden 1. Nintendo 64 Controller D-Pad Replacement: adım 7, 2 resimden 2.
    • Snap the back cover into place.
    • Use a Phillips #0 screwdriver to replace the screws on the back cover.
Sonuç
Happy gaming!
Bir başkası bu kılavuzu tamamladı.
Jamie Durman
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 334
