Nintendo DSi LED Indicator Board Replacement
Giriş
1. adıma gitUse this guide to replace the three status LEDs on the hinge of your DSi.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Bu adımda kullanılan alet:Tweezers$4.99
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on power board ZIF connector.
After flipping up the locking tab on the socket, use your fingers or a pair of tweezers to gently pull the cable straight out of its socket.
Bir başkası bu kılavuzu tamamladı.
