Ana içeriğe geç
Nintendo DSi Power Board Replacement
  1. Nintendo DSi Power Board Replacement, Battery: adım 1, 2 resimden 1. Nintendo DSi Power Board Replacement, Battery: adım 1, 2 resimden 2.
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift out of the lower case.
  2. Nintendo DSi Power Board Replacement: adım 2, 2 resimden 1. Nintendo DSi Power Board Replacement: adım 2, 2 resimden 2.
    • Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Power Board Replacement, Lower Case Assembly: adım 3, 2 resimden 1. Nintendo DSi Power Board Replacement, Lower Case Assembly: adım 3, 2 resimden 2.
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
  4. Nintendo DSi Power Board Replacement: adım 4, 1 resimden 1.
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Power Board Replacement: adım 5, 3 resimden 1. Nintendo DSi Power Board Replacement: adım 5, 3 resimden 2. Nintendo DSi Power Board Replacement: adım 5, 3 resimden 3.
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Power Board Replacement: adım 6, 2 resimden 1. Nintendo DSi Power Board Replacement: adım 6, 2 resimden 2.
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Power Board Replacement, Power Board: adım 7, 1 resimden 1.
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  8. Nintendo DSi Power Board Replacement: adım 8, 2 resimden 1. Nintendo DSi Power Board Replacement: adım 8, 2 resimden 2.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on power board ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • After flipping up the locking tab on the socket, use your fingers or a pair of tweezers to gently pull the cable straight out of its socket.
  9. Nintendo DSi Power Board Replacement: adım 9, 2 resimden 1. Nintendo DSi Power Board Replacement: adım 9, 2 resimden 2.
    • Remove the five 2.6 mm Phillips screws securing the power board to the DSi's framework.
    • Lift and remove the power board out of the DSi.
  10. Nintendo DSi Power Board Replacement: adım 10, 2 resimden 1. Nintendo DSi Power Board Replacement: adım 10, 2 resimden 2.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on LED indicator ZIF connector.
    • If necessary, transfer the power board ribbon cable to your new power board.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
3 Comments
So when I was attempting to repair my DSI, the red cable became unplugged and now my system won’t turn on. What can I do to fix this before I go the option of getting replaced or ordering replacement parts?
{Zantrock} - Yanıt
I need help. I busted off the connection of the power board to the mother board. Is there any way I can solder the red and black wires directly? Because the white piece is broken and gone now.
Jack Meloche - Yanıt
Hi I would like to ask about the buttons because in my case a plastic like bubble appeared on top of the contact gray button and it doesn’t make the pop sound anymore like the others that also means that it doesn’t work anymore could you help me?
Aleix M.G. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 34
Son 30 gün: 144
Her zaman: 27,703
