Ana içeriğe geç
Nintendo DSi Upper LCD/Speakers Replacement
Neye ihtiyacın var
  1. Nintendo DSi Upper LCD/Speakers Replacement, Battery Cover Removal: adım 1, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement, Battery Cover Removal: adım 1, 2 resimden 2.
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Upper LCD/Speakers Replacement, Taking out the Battery: adım 2, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement, Taking out the Battery: adım 2, 2 resimden 2.
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
    This is also where the water damage indicator is located, if that's important
    Vaulto - Yanıt
  3. Nintendo DSi Upper LCD/Speakers Replacement, Lower Case Assembly: adım 3, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement, Lower Case Assembly: adım 3, 2 resimden 2.
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
    One of the feet did break on me, tweezers came in handy for picking it out
    Willie Narvaez - Yanıt
    I unfolded and sharpened a paperclip. You can use that to stab and hook the rubber without tearing it, as the rubber is thick enough to reseal when reinserted.
    Keegan Andersen -
    Nasty, broke my spudger and the feet in this step.
    TimedIn - Yanıt
  4. Nintendo DSi Upper LCD/Speakers Replacement: adım 4, 1 resimden 1.
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
    Impossible d'enlever les vises… trop serré! comment faire?
    evrobert03 - Yanıt
    i can't get the screw by the gamecard slot out, PH#00 is too small and PH#0 is too big
    Iblowup - Yanıt
    same problem here. maybe try a JIS?
    darth mango -
  5. Nintendo DSi Upper LCD/Speakers Replacement: adım 5, 3 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 5, 3 resimden 2. Nintendo DSi Upper LCD/Speakers Replacement: adım 5, 3 resimden 3.
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Upper LCD/Speakers Replacement: adım 6, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 6, 2 resimden 2.
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
    Any help removing the ribbon cable, I have absolutely no clue how to remove this.
    John Brodie - Yanıt
  7. Nintendo DSi Upper LCD/Speakers Replacement, Wi-Fi Board: adım 7, 1 resimden 1.
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Upper LCD/Speakers Replacement: adım 8, 1 resimden 1.
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    After reassembling it, I switched my Nintendo DSi xl On and only the blue power light, is on after that it doesn't respond any more, except while charging it blinks
    Phillips - Yanıt
  9. Nintendo DSi Upper LCD/Speakers Replacement, Motherboard: adım 9, 1 resimden 1.
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
    do not pry up! pull to one side so you don't disconnect the clip from the motherboard!
    Lisa - Yanıt
    Actually Lisa, you are incorrect. If you pull to one side you WILL end up pulling the connector off the motherboard. It is designed so that you ARE MEANT TO pry it upwards out of the connector. All you need to do is use the point or corner of the flat edge of a spudger (or a small flat-headed screwdriver), push it ever so slightly under the middle of the small white plug where there is a small recess in the connector for just this purpose. Prying the plug up in this fashion you should clear the connector with the spudger by prying it up through the recess rather than catching the connector and pulling it off the board.
    James Gravestock -
    how to fix if the clip comes off of the motherboard?? please help!
    jaime - Yanıt
    Push it back in straight if it is still in one piece.
    Tman Tech -
    If the socket comes off the motherboard along with the connector, what’s the best way to fix it?
    Kimberly Meyer - Yanıt
    it has to be soldered back on, so if you can't do it yourself, find someone who can (maybe a local repair shop).
    just some mango -
    I already pull it off from board new i have to learn how to weld it back
    Mussa Ding - Yanıt
  10. Nintendo DSi Upper LCD/Speakers Replacement: adım 10, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
    I accidentally broke the retaining flap off of the lower touchscreen’s socket. Is it possible to reattach it?
    Thewolfpack23x - Yanıt
    Mine broke off too. At first I thought it would just pop back in, but when I looked at it under magnification, I can see that a tiny piece of plastic actually snapped off the flap. I think we're farked. Looks like the only way to fix would be to solder on a new cable connector.
    trevorsklar -
    i love and hate flex cables.
    they are flat and awesome, but every single flap for the connectors has broken for me (past experience vent lmao)
    Vaulto - Yanıt
  11. Nintendo DSi Upper LCD/Speakers Replacement: adım 11, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 11, 2 resimden 2.
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
    When I was putting mine back together, the flap popped off and when I tried to put it on with a tweezers, it snapped. Any suggestions other than scrap it or use it without the touchscreen? Pictures at https://sites.google.com/site/memesbyluc...
    Lucas Hoekstra (Lucas9810) - Yanıt
    This little flap is a pain in the butt to get back in! If there is any way to bypass the removal of this, my advise is to do it!
    Tamara Girodie - Yanıt
    Adding on: The cable actually ended up breaking as the tweezers I used to put it back in scraped part of the gold ribbon off. Be extremely careful!!!
  12. Nintendo DSi Upper LCD/Speakers Replacement: adım 12, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 12, 2 resimden 2.
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
    This one's super annoying to get back in
    FarmYard Gaming - Yanıt
  13. Nintendo DSi Upper LCD/Speakers Replacement: adım 13, 1 resimden 1.
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  14. Nintendo DSi Upper LCD/Speakers Replacement: adım 14, 1 resimden 1.
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  15. Nintendo DSi Upper LCD/Speakers Replacement: adım 15, 3 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 15, 3 resimden 2. Nintendo DSi Upper LCD/Speakers Replacement: adım 15, 3 resimden 3.
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
    I actually chose to leave this ribbon cable connected, and had no issues completing the rest of the steps around this. Just be careful not to pull the cable!
  16. Nintendo DSi Upper LCD/Speakers Replacement, Lower LCD Assembly: adım 16, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement, Lower LCD Assembly: adım 16, 2 resimden 2.
    • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
    • Lift the lower LCD assembly out of the DSi.
    It’s not mentioned here, but I found it easiest to just remove the buttons and rubber backings here as well - they will likely just fall out anyway when moving the case around and you may lose them.
    Tplan - Yanıt
  17. Nintendo DSi Upper LCD/Speakers Replacement, Upper LCD/Speakers: adım 17, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement, Upper LCD/Speakers: adım 17, 2 resimden 2.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
    Is there a good way to get these out without damaging them? Using a push pin or exacto-knife usually still damages them some.
    Or can you get replacements?
    Tplan - Yanıt
  18. Nintendo DSi Upper LCD/Speakers Replacement: adım 18, 1 resimden 1.
    • Remove the four Phillips screws securing the rear bezel to the front bezel.
  19. Nintendo DSi Upper LCD/Speakers Replacement: adım 19, 3 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 19, 3 resimden 2. Nintendo DSi Upper LCD/Speakers Replacement: adım 19, 3 resimden 3.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
    • Slightly close the case of the DSi and lift the rear bezel straight up out of the DSi.
  20. Nintendo DSi Upper LCD/Speakers Replacement: adım 20, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 20, 2 resimden 2.
    • Continue de-routing the microphone and Wi-Fi antenna cables through the opening located on the bottom DSi's framework.
    Same as above:
    Tplan - Yanıt
  21. Nintendo DSi Upper LCD/Speakers Replacement: adım 21, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 21, 2 resimden 2.
    • Remove the five Phillips screws securing the power board to the DSi's framework.
    • Lift and remove the power board from the DSi.
  22. Nintendo DSi Upper LCD/Speakers Replacement: adım 22, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 22, 2 resimden 2.
    • Push the metal hinge pin inward on the D-pad side of the front lower panel with the tip of a spudger.
    • The pin should move about 3 mm and stop. It is not necessary to try to completely remove the pin.
  23. Nintendo DSi Upper LCD/Speakers Replacement: adım 23, 3 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 23, 3 resimden 2. Nintendo DSi Upper LCD/Speakers Replacement: adım 23, 3 resimden 3.
    • Slightly detach the lower and upper halves of the DSi.
    • Do not completely separate both halves yet. There are several ribbon cables that remain threaded through both panels.
    • De-route the upper LCD and dual camera ribbon cables through the slit near the ABXY side of the front lower panel.
    • Separate the lower and upper halves from each other.
  24. Nintendo DSi Upper LCD/Speakers Replacement: adım 24, 1 resimden 1.
    • Using your fingers, grasp the microphone cable and de-route it through the hinge.
    • The microphone will likely pop out of its housing, so it is probably easier to completely remove it at this point.
    • De-route the Wi-Fi cable through the hinge.
  25. Nintendo DSi Upper LCD/Speakers Replacement: adım 25, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 25, 2 resimden 2.
    • Tightly coil the display and dual camera ribbon cables enough to push them through the steel hinge tube.
    • Remove the steel hinge tube.
    • Carefully push both coiled ribbon cables through the tube molded into the front upper panel.
    When reversing this after putting the new screen in, the larger of these two ribbon cables will be built into the new screen.
    I found it easiest to spend some time coiling the new ribbon cable from the middle up to the end, similar to how the old screen’s ribbon cable is coiled.
    This makes moving it back through the molded tube in the housing and then slipping the steel hinge tube a lot easier.
    Surprisingly, these cables are pretty sturdy - I’ve kinked one or two and it still functions, however I’d still say take it slow and try to avoid anything like that.
    Tplan - Yanıt
  26. Nintendo DSi Upper LCD/Speakers Replacement: adım 26, 1 resimden 1.
    • Pry the front-facing camera straight up out of its housing in the front bezel.
  27. Nintendo DSi Upper LCD/Speakers Replacement: adım 27, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 27, 2 resimden 2.
    • Lift the rear-facing camera out of its housing in the front bezel.
    • Remove the dual camera cable assembly from the DSi.
  28. Nintendo DSi Upper LCD/Speakers Replacement: adım 28, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 28, 2 resimden 2.
    • De-route the Wi-Fi antenna cable from its channel in the front bezel.
    • Lift the Wi-Fi antenna board straight up and remove it from the DSi.
  29. Nintendo DSi Upper LCD/Speakers Replacement: adım 29, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 29, 2 resimden 2.
    • Use the flat end of a spudger to pry the right speaker straight up and out of its housing in the front upper panel.
    • Lift the right speaker and set it on top of the upper LCD.
  30. Nintendo DSi Upper LCD/Speakers Replacement: adım 30, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 30, 2 resimden 2.
    • In the same manner as previously described, remove the left speaker.
    • De-route the left speaker cables from underneath the upper LCD.
    • Lay the left speaker on top of the upper LCD.
  31. Nintendo DSi Upper LCD/Speakers Replacement: adım 31, 2 resimden 1. Nintendo DSi Upper LCD/Speakers Replacement: adım 31, 2 resimden 2.
    • Cautiously wedge the flat end of spudger underneath the upper LCD.
    • Loosen the adhesive by running the spudger along the perimeter of the upper LCD.
    • Lift the upper LCD by its upper right corner and remove it from the front upper panel.
  32. Nintendo DSi Upper LCD/Speakers Replacement: adım 32, 1 resimden 1.
    • Desolder the speakers from the upper LCD by heating up the solder joints with a soldering iron and simultaneously using a pair of tweezers to pull the speaker wires away from the logic board.
    • If you have never soldered before, we have a guide that makes it easy.
    On step 10: I accidentally pried up the "Power Board Cable." (Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.) Is there an easy way to make it reconnect? I can't get it to stay back on mother board. I've attempting to get my DSI repaired, but many local stores and including manufacture Nintendo aren't offering assistance so I figured I'd fix it myself. Please assist if you can.
    Mayor LiteFoot - Yanıt
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
14Kılavuz Yorumları
The tricky part is getting the upper screen and black ribbon through the hinge. I found that curling them and pushing them through a drinking straw that was cut short first and then pushing the straw through the hinge hole made it a whole lot easier.
Damian - Yanıt
So true. I just broke my second ribbon cable while replacing the case. While most repairs on the dsi are relatively easy, this ribbon cable makes any repairs that involve it a nightmare.
Brendan Smith -
I curled the larger (new) cable the same way the smaller one was already curled. Just spend some time doing that until it was shaped that way and it was a lot easier to get both through the molded tube and ring.
Tplan -
I used this guide for change the cover broken by my son.
Thank you
Bompa (Italy)
Bompa - Yanıt
While doing this I accident messed something up. When I power on the DSi, the bottom screen just flashes and the DS turns off. What did I do wrong?
Ruben Colon - Yanıt
I think you broke the ribbon cable, it also happened to me, sadly the ribbon cable is soldered into the top screen so you need to buy a new top screen
Rubio Mejia -
make sure you plugged in the screen correctly, it's a bit fiddly because of how there's another cable overlaid on top of it, but both need to be properly seated otherwise you won't get a boot
Kaleb White -
Hey guys, i have two problems....
I have ordered a replacement housing for my daughter, so i hat to completely and fully disassemble everything.
Now I put it back together and first off, i have two strange square washer left AND, the upper screen turns on fine, the lower too.. but after 1 second, the upper screen gets all strange... colors are wrong.. I close the Lid, open it up and again, 1 second perfect, after that it turns discolored...
Any idea where the two washer could come from as i cant find them in the Description here and also what could be wrong with the display now?
Caylean Koar - Yanıt
Why do you need to disassemble your DSi on the bottom? Why is that important on every DS/3DS console? I would never do something with "Very difficult" tasks.
Santi12008 - Yanıt
Great guide.
it was hard, i ripped the broken lcd flat cable and it was hard to put the new one through the hinge, but i did it.
Then, when putting everything back together, i broke the sd card flat cable, %#*@ you manufacturer.. why such a flimsy cable with strong glue to the case?
be careful, the sd card connector is hard to reconnect and when you try to release it from the case, it may break
Ciro Monteiro - Yanıt
"Just do it backwards" is NOT helpful reassembly instructions because the hinge doesn't work that way. To "do it backwards" would be somehow sucking it in via the area above the dpad which is physically impossible. In order to reinsert the hinge, you need to get all the ribbon cables threaded through and the wires on the other side, before putting the top front plate back on, then slide the hinge piece into the top inner shell from the outside until it is flush with the hole it goes into. Then line back up the bottom inner plate, and push it "out" towards the place the LEDs will be, from the gap below the top LCD. I had to look up a separate video of someone doing this, and I'm afraid that in trying to figure it out myself using this guide I might have deformed the hinge somehow because I cannot for the life of me get it to go back where it needs to go.
jcryay - Yanıt
Your last comment is what I am literally struggling with right now. I cannot get the hinge to go back where it needs to go.
Mayor LiteFoot -
This is a terrible guide that is guaranteed to break your top screen ribbon cable if you follow it. The cable will not go through the slot as easy as they'd imply based on the positioning they suggest and curling it and pushing it through the hinge will absolutely break it if you didn't break it following that prior step.
A smarter way to do this would have been to remove the LCD screen and other attachments first and then gently curl the cable and pull it through. Would have resulted in far less force on the cable and far less risk of breakage.
Beyond that, this guide isn't even finished as it's missing the entire remaining half of how to actually put in a new screen. I'm noting a trend of that on all of the DSi guides.
Really abysmal work here. Really shocked that this is an official guide, I thought you guys were better than this.
troubled-pasta - Yanıt
I've never replaced a screen like this before and I got it done just fine following the guide. Sounds like a you problem.
Devil intheWoods -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 102
Son 30 gün: 429
Her zaman: 60,837
