Ana içeriğe geç
Joy-Con Buckle Lock Replacement
Neye ihtiyacın var
  1. Joy-Con Buckle Lock Replacement, Remove the case screws: adım 1, 1 resimden 1.
    • Use a Tri-point Y00 driver to remove the four 6.3 mm-long screws from the back panel of the Joy-Con.
  2. Joy-Con Buckle Lock Replacement, Separate the halves of the Joy-Con: adım 2, 3 resimden 1. Joy-Con Buckle Lock Replacement, Separate the halves of the Joy-Con: adım 2, 3 resimden 2. Joy-Con Buckle Lock Replacement, Separate the halves of the Joy-Con: adım 2, 3 resimden 3.
    • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
    • Slowly slide the flat edge of your opening pick up the side of the Joy-Con.
    • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel loosens easily, so not much pressure is needed.
  3. Joy-Con Buckle Lock Replacement, Open the Joy-Con: adım 3, 2 resimden 1. Joy-Con Buckle Lock Replacement, Open the Joy-Con: adım 3, 2 resimden 2.
    • With the charging rail facing away from you, open the the Joy-Con like a book.
    • Don’t try to fully remove the back panel. There are still two cables connecting the charging rail to the motherboard.
  4. Joy-Con Buckle Lock Replacement, Unscrew the charging rail: adım 4, 1 resimden 1.
    • Use a Phillips #00 driver to remove the 2.5 mm screw securing the charging rail.
  5. Joy-Con Buckle Lock Replacement, Remove the back panel: adım 5, 2 resimden 1. Joy-Con Buckle Lock Replacement, Remove the back panel: adım 5, 2 resimden 2.
    • Pull the back panel straight off of the charging rail to remove it.
    • There's a chance the rail unlock button will fall out of the back panel. During reassembly, make sure it is installed correctly, with the tab on the button slotted into the notch in the back panel.
  6. Joy-Con Buckle Lock Replacement, Remove the buckle lock bracket: adım 6, 1 resimden 1.
    • Use a Phillips #00 driver to remove the screw securing the buckle lock retaining bracket.
  7. Joy-Con Buckle Lock Replacement: adım 7, 3 resimden 1. Joy-Con Buckle Lock Replacement: adım 7, 3 resimden 2. Joy-Con Buckle Lock Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Slide one side of a pair of pointed tweezers under the flat part in the middle of the buckle lock bracket.
    • Grasp the bracket with the tweezers and pull the bracket straight away from the charging rail to remove it.
    • Be careful when you remove the bracket, as the spring and old buckle lock may shoot out and be easily lost.
  8. Joy-Con Buckle Lock Replacement, Remove the buckle lock: adım 8, 3 resimden 1. Joy-Con Buckle Lock Replacement, Remove the buckle lock: adım 8, 3 resimden 2. Joy-Con Buckle Lock Replacement, Remove the buckle lock: adım 8, 3 resimden 3.
    • Lift the buckle lock slightly out of its slot in the charging rail, just until the spring is exposed enough that you can grab it with tweezers.
    • Grab the buckle lock such that the tweezers are around both sides of the lock and holding the spring inside the lock.
    • When you pull the lock out, the spring can shoot out. Make sure you have a firm grip with the tweezers.
    • Pull the buckle lock out of its slot in the charging rail.
    • During reassembly, make sure to move the spring from the old lock to the new one.
Sonuç
112 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
196.940 İtibar
416 adet Kılavuz yazıldı
34 Yorum
I tried to do this carefully, but I ended up removing the side rail ribbon cables and I had to disassemble the whole thing just to try to get to the inside of these babies. However it seems I messed up, and now I could use some help here. I don't want to lose my left Joy-Con.
Francisco Q. - Yanıt
It seems rather strange.. Its pretty easy to reattach. All I have is a $@$*!& ph00 + y00 that stripped the screws so I broke the cover. Technically not my fault. I have done multiple reshells.
[deleted] -
I tryed to do this but the 2nd at the bottom would not come out now my buckle is chiped
TAQI HASSAN - Yanıt
You mean the screws? Break off the shell! A perfect opportunity to put some clear ones :))
[deleted] -
I bought this kit of replacement metal buckles, and they work beautifully: https://www.amazon.com/gp/product/B07BDH...
This kit comes with four buckles, two for the left Joy Con, and two for the right. If you happen to have two sets (or plan to get a second set) of Joy Cons, a whopping $9.00 will set you up right.
I did have a bit of trouble replacing the metal cover that holds the buckle in place, but that was my own stupidity as I was trying to do this repair with insufficient light. Once I shed some light on the subject and I could see what I was doing, everything went back together smooth as silk. I replaced the buckles on both of my Joy Cons, and they’re both rock solid now.
itpurchasing - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 73
Son 7 gün: 466
Son 30 gün: 2,037
Her zaman: 125,309
