Giriş
Use this guide to replace the rear case in your Nintendo Switch OLED.
The Switch OLED uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Neye ihtiyacın var
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
Use your finger to flip up the kickstand on the back of the device.
Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
5 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Where do I buy the rear case from not listed in this article
Hi Ruben!
I added the part to the guide. Unfortunately, at the time of me writing this, we are out of stock. You can get notified when we get more in stock on the part's page!
Great write-up guide and all the proper tools for repair! I did go to YouTube for a quick video, which suggested using a low setting on a heat gun to help warm the glue holding the old battery in place. I can’t comment on the safety of that, but it certainly helped. Out of everything during the battery replacement, removing the old battery was the toughest part of the process. Otherwise, it was easy to fix it myself with the iFixit kit. 5 stars!
