Ana içeriğe geç
Nintendo WaveBird Wireless Controller C-Stick Replacement
Neye ihtiyacın var
  1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: adım 1, 2 resimden 2.
    • Pull down on the battery cover release lever and pull back to remove the cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo WaveBird Wireless Controller C-Stick Replacement: adım 2, 1 resimden 1.
    • Remove both batteries from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: adım 3, 2 resimden 2.
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo WaveBird Wireless Controller C-Stick Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller C-Stick Replacement: adım 4, 2 resimden 2.
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: adım 5, 3 resimden 1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: adım 5, 3 resimden 2. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: adım 6, 2 resimden 1. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: adım 6, 2 resimden 2.
    • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
    • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
    • Pull off the yellow C-Stick cover.
    • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Garrett Leung
979 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
44 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 3,051
