Ana içeriğe geç
Nintendo WaveBird Wireless Controller Joystick Replacement
Neye ihtiyacın var
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: adım 1, 2 resimden 2.
    • Pull down on the battery cover release lever and pull back to remove the cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: adım 2, 1 resimden 1.
    • Remove both batteries from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: adım 3, 2 resimden 2.
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller Joystick Replacement: adım 4, 2 resimden 2.
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: adım 5, 3 resimden 1. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: adım 5, 3 resimden 2. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: adım 6, 2 resimden 1. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: adım 6, 2 resimden 2.
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Garrett Leung
979 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
44 adet Kılavuz yazıldı
1Rehber Yorum
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 20
Son 30 gün: 101
Her zaman: 11,512
