Ana içeriğe geç
Nintendo WaveBird Wireless Controller Motherboard Replacement
Neye ihtiyacın var
  1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: adım 1, 2 resimden 2.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: adım 3, 2 resimden 2.
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Motherboard Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller Motherboard Replacement: adım 4, 2 resimden 2.
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: adım 5, 3 resimden 1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: adım 5, 3 resimden 2. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Using tweezers remove the three grey button pads from the motherboard.
  7. Nintendo WaveBird Wireless Controller Motherboard Replacement: adım 7, 1 resimden 1.
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Travis Taylor
521 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 51
Her zaman: 9,122
