Ana içeriğe geç
Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement
Neye ihtiyacın var
  1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Batteries: adım 1, 2 resimden 2.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 2, 1 resimden 1.
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Front Panel: adım 3, 2 resimden 2.
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 4, 2 resimden 2.
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Buttons: adım 5, 3 resimden 1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Buttons: adım 5, 3 resimden 2. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Buttons: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Motherboard: adım 6, 1 resimden 1.
    • Using tweezers remove the three grey button pads from the motherboard.
  7. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 7, 1 resimden 1.
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
  8. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Shoulder Buttons: adım 8, 3 resimden 1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Shoulder Buttons: adım 8, 3 resimden 2. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Shoulder Buttons: adım 8, 3 resimden 3.
    • Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
    • Lift off the black plastic covers that secure the shoulder buttons.
  9. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 9, 3 resimden 1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 9, 3 resimden 2. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 9, 3 resimden 3.
    • Using the screwdriver, carefully unlock the spring clip from its holder.
    • Once unlocked, use tweezers to pull springs out of its holster.
    • The springs will try to jump out. Be careful not to lose them when setting them aside.
    • When reattaching the clips, use tweezers to align the clip with its holder and press in until it clicks.
  10. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: adım 10, 1 resimden 1.
    • Once the spring is removed, take out the shoulder buttons by pulling down and out.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Travis Taylor
521 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
37 adet Kılavuz yazıldı
1Rehber Yorum
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
Lucas Brownlee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 3,536
