Giriş
This guide was made to help complete the replacement of faulty Bluetooth and Wi-Fi boards in the 2011 Nintendo Wii. This guide will be repairing the issue of faulty connection due to poor soldering of the circuit boards.
The model number for the Wii is RVL-101 otherwise known as the “Wii Family Edition”. Note: Follow pre-requisite guide “Nintendo Wii 2011 Disassembly” to step 18.
This guide requires soldering to complete. If you are unfamiliar with soldering, check out this helpful article.
Neye ihtiyacın var
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the device.
Pull out the slot with the battery (pictured in the third photo). Leave both the battery and the slot organized on the side with the removed screw.
After gaining access to the boards unscrew the 3mm screws holding the Bluetooth and Wi-Fi boards in place using the Philips #0 screwdriver.
To reassemble your device after the replacement, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
