Ana içeriğe geç
Nintendo Wii 2011 DVD Drive Replacement/Repair
Neye ihtiyacın var
  1. Nintendo Wii 2011 DVD Drive Replacement/Repair, DVD Drive: adım 1, 1 resimden 1.
    • Follow Nintendo Wii 2011 Outer Case Removal/Dissassemby up to step 14.
    • Begin this guide on the metal casing side of the DVD drive.
    • Steps 2-6 of this guide will walk you through attempting to move/adjust components of the drive that may have become jammed in place.
    FixBot'a Sor
  2. Nintendo Wii 2011 DVD Drive Replacement/Repair: adım 2, 1 resimden 1.
    • Try to adjust the white plastic component found in the hole in the metal case. It should move freely, if not try to wiggle it until it does.
    FixBot'a Sor
  3. Nintendo Wii 2011 DVD Drive Replacement/Repair: adım 3, 1 resimden 1.
    • Next, attempt to slide the white plastic component along the arch-shaped cut out in the metal case. It should move freely when the drive is open.
    FixBot'a Sor
  4. Nintendo Wii 2011 DVD Drive Replacement/Repair: adım 4, 1 resimden 1.
    • Repeat step 3 with the identical component 2 inches above the first one.
    FixBot'a Sor
  5. Nintendo Wii 2011 DVD Drive Replacement/Repair: adım 5, 1 resimden 1.
    • Attempt to manipulate the white plastic component shown in the photo. If it is jammed, the disc drive may have broken internal components.
    FixBot'a Sor
  6. Nintendo Wii 2011 DVD Drive Replacement/Repair: adım 6, 1 resimden 1.
    • Flip over the DVD disc drive. Along one edge is a long white rail on gears for moving the DVD in and out of the drive. Slide it along its track, it should snap back into place. If not, there may be internal damage to the DVD drive.
    FixBot'a Sor
  7. Nintendo Wii 2011 DVD Drive Replacement/Repair: adım 7, 1 resimden 1.
    • If none of those adjustments fix the problem with your DVD drive, you will need to replace it.
    • Follow the steps for removing the DVD drive in reverse to install a new DVD drive.
    FixBot'a Sor
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Disc read error is a common issue. To tell if the laser is faulty take the shell off of the wii and insert a disc in the drive and see if a red light comes on where the disc is spinning.
Brett J - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 28
Son 30 gün: 126
Her zaman: 6,209
