Ana içeriğe geç
Nobis NB07 Battery Replacement
Neye ihtiyacın var
  1. Nobis NB07 Battery Replacement, Opening the case: adım 1, 1 resimden 1.
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Battery Replacement: adım 2, 3 resimden 1. Nobis NB07 Battery Replacement: adım 2, 3 resimden 2. Nobis NB07 Battery Replacement: adım 2, 3 resimden 3.
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Battery Replacement, Replacing the battery: adım 3, 3 resimden 1. Nobis NB07 Battery Replacement, Replacing the battery: adım 3, 3 resimden 2. Nobis NB07 Battery Replacement, Replacing the battery: adım 3, 3 resimden 3.
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Battery Replacement: adım 4, 3 resimden 1. Nobis NB07 Battery Replacement: adım 4, 3 resimden 2. Nobis NB07 Battery Replacement: adım 4, 3 resimden 3.
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Battery Replacement: adım 5, 1 resimden 1.
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Battery Replacement: adım 6, 2 resimden 1. Nobis NB07 Battery Replacement: adım 6, 2 resimden 2.
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Daniel Gomero
966 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G5
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
where do you find that battery? tried searching by the numbers on it and nothing
Scott Tuttle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 3,266
