Ana içeriğe geç
Nobis NB07 Microphone Replacement
Neye ihtiyacın var
    1. Nobis NB07 Microphone Replacement, Opening the case: adım 1, 1 resimden 1.
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      FixBot'a Sor
      Yorum Ekle
    2. Nobis NB07 Microphone Replacement: adım 2, 3 resimden 1. Nobis NB07 Microphone Replacement: adım 2, 3 resimden 2. Nobis NB07 Microphone Replacement: adım 2, 3 resimden 3.
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      FixBot'a Sor
      Yorum Ekle
    3. Nobis NB07 Microphone Replacement, Replacing the battery: adım 3, 3 resimden 1. Nobis NB07 Microphone Replacement, Replacing the battery: adım 3, 3 resimden 2. Nobis NB07 Microphone Replacement, Replacing the battery: adım 3, 3 resimden 3.
      • Remove the tape holding the battery in place.
      FixBot'a Sor
      Yorum Ekle
    4. Nobis NB07 Microphone Replacement: adım 4, 3 resimden 1. Nobis NB07 Microphone Replacement: adım 4, 3 resimden 2. Nobis NB07 Microphone Replacement: adım 4, 3 resimden 3.
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      FixBot'a Sor
      Yorum Ekle
    5. Nobis NB07 Microphone Replacement: adım 5, 1 resimden 1.
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      FixBot'a Sor
      Yorum Ekle
    6. Nobis NB07 Microphone Replacement: adım 6, 2 resimden 1. Nobis NB07 Microphone Replacement: adım 6, 2 resimden 2.
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Nobis NB07 Microphone Replacement, Removing the cameras: adım 7, 3 resimden 1. Nobis NB07 Microphone Replacement, Removing the cameras: adım 7, 3 resimden 2. Nobis NB07 Microphone Replacement, Removing the cameras: adım 7, 3 resimden 3.
      • Remove the black tape covering the cameras power cable.
      FixBot'a Sor
      Yorum Ekle
    2. Nobis NB07 Microphone Replacement: adım 8, 2 resimden 1. Nobis NB07 Microphone Replacement: adım 8, 2 resimden 2.
      • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
      FixBot'a Sor
      Yorum Ekle
    3. Nobis NB07 Microphone Replacement: adım 9, 3 resimden 1. Nobis NB07 Microphone Replacement: adım 9, 3 resimden 2. Nobis NB07 Microphone Replacement: adım 9, 3 resimden 3.
      Bu adımda kullanılan alet:
      • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
      • Using tweezers, carefully grab the front camera and twist slowly.
      • The camera should release easily, do not twist too hard.
      • You can now remove the cameras.
      FixBot'a Sor
      Yorum Ekle
    1. Nobis NB07 Microphone Replacement, Removing the microphone: adım 10, 1 resimden 1.
      • Locate the microphone's cables in front of the cameras' ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    2. Nobis NB07 Microphone Replacement: adım 11, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    3. Nobis NB07 Microphone Replacement: adım 12, 2 resimden 1. Nobis NB07 Microphone Replacement: adım 12, 2 resimden 2.
      • Use the pointy end of the tweezers to retrieve the microphone from its socket.
      • You can now remove the microphone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Daniel Gomero
966 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G5
3 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 501
