Ana içeriğe geç
Nobis NB07 Speaker Replacement
Neye ihtiyacın var
    1. Nobis NB07 Speaker Replacement, Opening the case: adım 1, 1 resimden 1.
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      FixBot'a Sor
      Yorum Ekle
    2. Nobis NB07 Speaker Replacement: adım 2, 3 resimden 1. Nobis NB07 Speaker Replacement: adım 2, 3 resimden 2. Nobis NB07 Speaker Replacement: adım 2, 3 resimden 3.
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      FixBot'a Sor
      Yorum Ekle
    3. Nobis NB07 Speaker Replacement, Replacing the battery: adım 3, 3 resimden 1. Nobis NB07 Speaker Replacement, Replacing the battery: adım 3, 3 resimden 2. Nobis NB07 Speaker Replacement, Replacing the battery: adım 3, 3 resimden 3.
      • Remove the tape holding the battery in place.
      FixBot'a Sor
      Yorum Ekle
    4. Nobis NB07 Speaker Replacement: adım 4, 3 resimden 1. Nobis NB07 Speaker Replacement: adım 4, 3 resimden 2. Nobis NB07 Speaker Replacement: adım 4, 3 resimden 3.
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      FixBot'a Sor
      Yorum Ekle
    5. Nobis NB07 Speaker Replacement: adım 5, 1 resimden 1.
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      FixBot'a Sor
      Yorum Ekle
    6. Nobis NB07 Speaker Replacement: adım 6, 2 resimden 1. Nobis NB07 Speaker Replacement: adım 6, 2 resimden 2.
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Nobis NB07 Speaker Replacement, Removing the speaker: adım 7, 3 resimden 1. Nobis NB07 Speaker Replacement, Removing the speaker: adım 7, 3 resimden 2. Nobis NB07 Speaker Replacement, Removing the speaker: adım 7, 3 resimden 3.
      • Remove the tape holding the speaker in its socket.
      FixBot'a Sor
      Yorum Ekle
    2. Nobis NB07 Speaker Replacement: adım 8, 2 resimden 1. Nobis NB07 Speaker Replacement: adım 8, 2 resimden 2.
      • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
      • Look for the place where the speaker's cables meet with the motherboard.
      • Annotate where which color goes to make the reassembly easier.
      FixBot'a Sor
      Yorum Ekle
    3. Nobis NB07 Speaker Replacement: adım 9, 2 resimden 1. Nobis NB07 Speaker Replacement: adım 9, 2 resimden 2.
      • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
      • You can now remove the speaker.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Daniel Gomero
966 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G5
3 Üyeler
30 adet Kılavuz yazıldı
2Kılavuz Yorumları
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - Yanıt Paylaş
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 572
