Ana içeriğe geç
Nokia C7 - 00 Touchscreen Replacement
    1. Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: adım 1, 3 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: adım 1, 3 resimden 2. Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: adım 1, 3 resimden 3.
      • With a thin tool insert it in the cover at the bottom and pry up to release it
      FixBot'a Sor
      Yorum Ekle
    2. Nokia  C7 - 00 Touchscreen  Replacement: adım 2, 2 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 2, 2 resimden 2.
      • Pry up the two points indicated by the arrows to release the keyboard
      FixBot'a Sor
      Yorum Ekle
    3. Nokia  C7 - 00 Touchscreen  Replacement: adım 3, 2 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 3, 2 resimden 2.
      • Remove battery and battery cover
      FixBot'a Sor
      Yorum Ekle
    4. Nokia  C7 - 00 Touchscreen  Replacement: adım 4, 2 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 4, 2 resimden 2.
      • Unscrew the 2 rear screws
      • Unscrew the 2 front screws
      FixBot'a Sor
      Yorum Ekle
    5. Nokia  C7 - 00 Touchscreen  Replacement: adım 5, 3 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 5, 3 resimden 2. Nokia  C7 - 00 Touchscreen  Replacement: adım 5, 3 resimden 3.
      • Gently lift the front glass and slide it slightly in the direction of the arrow so you can free it
      FixBot'a Sor
      Yorum Ekle
    6. Nokia  C7 - 00 Touchscreen  Replacement: adım 6, 3 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 6, 3 resimden 2. Nokia  C7 - 00 Touchscreen  Replacement: adım 6, 3 resimden 3.
      • if the display needs to be replaced and then you have no problems if it is broken in the door, proceed with a heat source and a thin tool to be able to break it from underneath
      • If the display is as good as in my case to avoid the risk of breaking it, unscrew the two red arrow screws
      • Gradually unscrew the purple arrow screw so that you do not lose too much on the back of the display to avoid breaking it, at the same time lift it from the keyboard area and gradually unscrew Dino to the complete lifting of the display and its housing doing Leva also laterally on the releases
      FixBot'a Sor
      Yorum Ekle
    7. Nokia  C7 - 00 Touchscreen  Replacement: adım 7, 2 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 7, 2 resimden 2.
      • Lift up display assembly.
      FixBot'a Sor
      Yorum Ekle
    8. Nokia  C7 - 00 Touchscreen  Replacement: adım 8, 3 resimden 1. Nokia  C7 - 00 Touchscreen  Replacement: adım 8, 3 resimden 2. Nokia  C7 - 00 Touchscreen  Replacement: adım 8, 3 resimden 3.
      • Disconnect touch screen connector
      • Disconnect display connector
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble the device, follow these instructions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
12.359 İtibar
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 62
Her zaman: 3,060
