Ana içeriğe geç
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
James Szelenyi
James Szelenyi ve 3 diğer katkıda bulunanlar
En son September 8, 2017 tarihinde güncellendi
5 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
Eksik önkoşulları
This guide will show you how to install a new motherboard and keyboard unit in your phone.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: adım 1, 2 resimden 1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: adım 2, 1 resimden 1.
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: adım 3, 2 resimden 1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: adım 3, 2 resimden 2.
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
    You please Nokia 1100 Motherboard and keyboard Rely
    ajay gupta - Yanıt
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: adım 4, 2 resimden 1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: adım 4, 2 resimden 2.
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
James Szelenyi
286 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G43
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
you nokia 1100 mother board please soon date…?
ajay gupta - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 40
Her zaman: 4,610
