Ana içeriğe geç
Nokia 2630b Antenna Replacement
Neye ihtiyacın var
    1. Nokia 2630b Antenna Replacement, Battery Case: adım 1, 2 resimden 1. Nokia 2630b Antenna Replacement, Battery Case: adım 1, 2 resimden 2.
      • Press and the release button on both sides of the battery cover. While holding down the release buttons pull the battery cover away from the phone
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2630b Antenna Replacement: adım 2, 1 resimden 1.
      • Pull out the battery by holding the top of the battery and tilting out.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 2630b Antenna Replacement, Screen / Front Case: adım 3, 1 resimden 1.
      • Remove the two screws on either side of the battery case using a T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2630b Antenna Replacement: adım 4, 3 resimden 1. Nokia 2630b Antenna Replacement: adım 4, 3 resimden 2. Nokia 2630b Antenna Replacement: adım 4, 3 resimden 3.
      • Separate the front case from the back case using the iPod opener.
      • The keypad is a loose piece and may fall out.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia 2630b Antenna Replacement: adım 5, 1 resimden 1.
      • Remove screws using the T5 Torx screwdriver to release the computer chip from the case.
      FixBot'a Sor
      Yorum Ekle
    4. Nokia 2630b Antenna Replacement: adım 6, 1 resimden 1.
      • Carefully lift the black frame off the screen with your fingers.
      FixBot'a Sor
      Yorum Ekle
    5. Nokia 2630b Antenna Replacement: adım 7, 1 resimden 1.
      • Carefully remove the computer chip and screen out of the black case with your fingers.
      FixBot'a Sor
      Yorum Ekle
    6. Nokia 2630b Antenna Replacement: adım 8, 2 resimden 1. Nokia 2630b Antenna Replacement: adım 8, 2 resimden 2.
      • The screen is attached to the motherboard by an orange ribbon.
      • Carefully detach the ribbon from the motherboard using your fingers.
      FixBot'a Sor
      Yorum Ekle
    7. Nokia 2630b Antenna Replacement: adım 9, 1 resimden 1.
      • Reattach new screen by connecting the orange ribbon to the computer chip.
      FixBot'a Sor
      Yorum Ekle
    8. Nokia 2630b Antenna Replacement: adım 10, 2 resimden 1. Nokia 2630b Antenna Replacement: adım 10, 2 resimden 2.
      • Place computer chip and screen back into black case.
      FixBot'a Sor
      Yorum Ekle
    9. Nokia 2630b Antenna Replacement: adım 11, 1 resimden 1.
      • Place black frame back over screen.
      FixBot'a Sor
      Yorum Ekle
    10. Nokia 2630b Antenna Replacement: adım 12, 2 resimden 1. Nokia 2630b Antenna Replacement: adım 12, 2 resimden 2.
      • Carefully place keypad back in place.
      FixBot'a Sor
      Yorum Ekle
    11. Nokia 2630b Antenna Replacement: adım 13, 2 resimden 1. Nokia 2630b Antenna Replacement: adım 13, 2 resimden 2.
      • Snap the front case back in place with the bottom case with your fingers.
      FixBot'a Sor
      Yorum Ekle
    12. Nokia 2630b Antenna Replacement: adım 14, 1 resimden 1.
      • Reassemble screws with microscrewdriver.
      FixBot'a Sor
      Yorum Ekle
    13. Nokia 2630b Antenna Replacement: adım 15, 1 resimden 1.
      • Slide battery back into place.
      FixBot'a Sor
      Yorum Ekle
    14. Nokia 2630b Antenna Replacement: adım 16, 1 resimden 1.
      • Snap battery cover back into place.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 2630b Antenna Replacement, Back Case: adım 17, 2 resimden 1. Nokia 2630b Antenna Replacement, Back Case: adım 17, 2 resimden 2.
      • Locate the four screws that secure the back case to the rest of the phone.
      • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2630b Antenna Replacement: adım 18, 3 resimden 1. Nokia 2630b Antenna Replacement: adım 18, 3 resimden 2. Nokia 2630b Antenna Replacement: adım 18, 3 resimden 3.
      • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
      • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 2630b Antenna Replacement, Antenna: adım 19, 1 resimden 1.
      • The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
      • You should be able to remove the antenna with minimal effort.
      • To put in a new antenna, place it in the same location as the old one. There is no need to connect to any hardware on the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2630b Antenna Replacement: adım 20, 1 resimden 1.
      • To reassemble the device, follow the instructions in reverse order.
      • When reinstalling the keyboard, make sure it is in the correct position before screwing the case back together.
      • When reinstalling the battery, make sure the contacts of the battery connect to the contacts on the phone.
      • Double-check the position of the brass contacts in relation to the battery.
      • The photo displays the correct orientation of the battery.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Eric
57 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-61, Walters Spring 2011 Cal Poly, Team 9-61, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G61
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 4,050
