Giriş
Follow this guide to replace the Motherboard in your Nokia 2780 Flip.
The Motherboard is the main circuit board of the Nokia 2780 Flip and helps all the phone's parts work together, including the screen, buttons, battery, and charging port. If the motherboard stops working, the phone may not turn on, charge, or respond as expected. Replacing the motherboard can help restore the phone if other basic fixes do not solve the problem.
Before you begin the repair, ensure your phone is powered off and unplugged from the charger.
Neye ihtiyacın var
Insert an iFixit opening tool into the seam between the back case and the bottom edge of the phone.
Use a Torx T5 screwdriver to remove the six visible 1.4 mm screws that secure the internal rear housing.
Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
