Ana içeriğe geç
Nokia 3100b Microphone Replacement
Neye ihtiyacın var
  1. Nokia 3100b Microphone Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your phone is turned off.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 3100b Microphone Replacement: adım 2, 1 resimden 1.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 3100b Microphone Replacement, SIM Card: adım 3, 1 resimden 1.
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 3100b Microphone Replacement: adım 4, 1 resimden 1.
    • Retrieve your SIM card.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 3100b Microphone Replacement, Microphone: adım 5, 1 resimden 1.
    • Press the black tabs to release the front cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 3100b Microphone Replacement: adım 6, 1 resimden 1.
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 3100b Microphone Replacement: adım 7, 2 resimden 1. Nokia 3100b Microphone Replacement: adım 7, 2 resimden 2.
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 3100b Microphone Replacement: adım 8, 3 resimden 1. Nokia 3100b Microphone Replacement: adım 8, 3 resimden 2. Nokia 3100b Microphone Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Sterling Fuentes
139 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G64
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 2,468
