Ana içeriğe geç
Nokia 6085h Front LCD Display
Neye ihtiyacın var
  1. Nokia 6085h Front LCD Display, Battery: adım 1, 1 resimden 1.
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6085h Front LCD Display: adım 2, 1 resimden 1.
    • Remove the phone's battery.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6085h Front LCD Display, Front LCD Display: adım 3, 3 resimden 1. Nokia 6085h Front LCD Display, Front LCD Display: adım 3, 3 resimden 2. Nokia 6085h Front LCD Display, Front LCD Display: adım 3, 3 resimden 3.
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6085h Front LCD Display: adım 4, 2 resimden 1. Nokia 6085h Front LCD Display: adım 4, 2 resimden 2.
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6085h Front LCD Display: adım 5, 3 resimden 1. Nokia 6085h Front LCD Display: adım 5, 3 resimden 2. Nokia 6085h Front LCD Display: adım 5, 3 resimden 3.
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6085h Front LCD Display: adım 6, 1 resimden 1.
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6085h Front LCD Display: adım 7, 3 resimden 1. Nokia 6085h Front LCD Display: adım 7, 3 resimden 2. Nokia 6085h Front LCD Display: adım 7, 3 resimden 3.
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brett Balcer
240 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-46, Amido Fall 2010 Cal Poly, Team 4-46, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G46
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 1,640
