Ana içeriğe geç
Nokia 8290 Antenna Replacement
Neye ihtiyacın var
  1. Nokia 8290 Antenna Replacement, Front Cover: adım 1, 3 resimden 1. Nokia 8290 Antenna Replacement, Front Cover: adım 1, 3 resimden 2. Nokia 8290 Antenna Replacement, Front Cover: adım 1, 3 resimden 3.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Antenna Replacement, Antenna: adım 2, 3 resimden 1. Nokia 8290 Antenna Replacement, Antenna: adım 2, 3 resimden 2. Nokia 8290 Antenna Replacement, Antenna: adım 2, 3 resimden 3.
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Antenna Replacement: adım 3, 3 resimden 1. Nokia 8290 Antenna Replacement: adım 3, 3 resimden 2. Nokia 8290 Antenna Replacement: adım 3, 3 resimden 3.
    • After removing the circuit board/faceplate sub-assembly, locate the antenna.
    • Remove the antenna by prying it out with your fingers or a prying tool. It may help to turn the back portion of the phone over to allow the antenna to fall away.
Sonuç
Austin Culberson
87 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G3
3 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 473
