Ana içeriğe geç
Nokia 8290 Microphone Replacement
Neye ihtiyacın var
  1. Nokia 8290 Microphone Replacement, Front Cover: adım 1, 3 resimden 1. Nokia 8290 Microphone Replacement, Front Cover: adım 1, 3 resimden 2. Nokia 8290 Microphone Replacement, Front Cover: adım 1, 3 resimden 3.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 8290 Microphone Replacement, Circuit Board: adım 2, 3 resimden 1. Nokia 8290 Microphone Replacement, Circuit Board: adım 2, 3 resimden 2. Nokia 8290 Microphone Replacement, Circuit Board: adım 2, 3 resimden 3.
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 8290 Microphone Replacement: adım 3, 3 resimden 1. Nokia 8290 Microphone Replacement: adım 3, 3 resimden 2. Nokia 8290 Microphone Replacement: adım 3, 3 resimden 3.
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 8290 Microphone Replacement, Microphone: adım 4, 3 resimden 1. Nokia 8290 Microphone Replacement, Microphone: adım 4, 3 resimden 2. Nokia 8290 Microphone Replacement, Microphone: adım 4, 3 resimden 3.
    • Use the spudger to peel back the top-left corner of the white adhesive film. This can be done by working the spudger back and forth underneath the film.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 8290 Microphone Replacement: adım 5, 3 resimden 1. Nokia 8290 Microphone Replacement: adım 5, 3 resimden 2. Nokia 8290 Microphone Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Continue to peel the film back until you can see the microphone.
    • Use tweezers to remove the microphone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Parker Niebauer
7 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G3
3 Üyeler
33 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 702
