Ana içeriğe geç
Nook Simple Touch with GlowLight Battery Replacement
Neye ihtiyacın var
  1. Nook Simple Touch with GlowLight Battery Replacement, Power Button: adım 1, 1 resimden 1.
    • Place the Nook with the screen facing down.
    FixBot'a Sor
    Yorum Ekle
  2. Nook Simple Touch with GlowLight Battery Replacement: adım 2, 1 resimden 1.
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
    FixBot'a Sor
    Yorum Ekle
  3. Nook Simple Touch with GlowLight Battery Replacement: adım 3, 1 resimden 1.
    • Using your fingers, gently remove the power button.
    FixBot'a Sor
    Yorum Ekle
  4. Nook Simple Touch with GlowLight Battery Replacement, Back Cover: adım 4, 1 resimden 1.
    • Remove the single screw using a T4 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Nook Simple Touch with GlowLight Battery Replacement: adım 5, 1 resimden 1.
    • Slide the back cover down towards you in the direction of the charging port.
    FixBot'a Sor
    Yorum Ekle
  6. Nook Simple Touch with GlowLight Battery Replacement, Battery: adım 6, 2 resimden 1. Nook Simple Touch with GlowLight Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 70
Her zaman: 1,425
