Ana içeriğe geç
NuVision Duo 11 Battery Replacement
Neye ihtiyacın var
  1. NuVision Duo 11 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
    • Slide the spudger down each side until you hear numerous clicks.
    • Remove the back panel from the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. NuVision Duo 11 Battery Replacement, Battery: adım 2, 2 resimden 1. NuVision Duo 11 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Carefully remove any pieces of electrical tape that may be adhered to the battery.
    • The tape may be adhered to wires; be sure to pull up the tape slowly.
    FixBot'a Sor
    Yorum Ekle
  3. NuVision Duo 11 Battery Replacement: adım 3, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  4. NuVision Duo 11 Battery Replacement: adım 4, 1 resimden 1.
    • Gently peel the battery from the front case.
    • You will be met with some resistance, so it is critical that you are very careful.
    • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Gavin Amaral
377 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G1
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 751
