Giriş
This guide shows how to replace the audio jack without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Neye ihtiyacın var
Turn the Numark N4 over so that the bottom panel is facing upwards.
Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
