Giriş
A faulty USB can cause a host of different problems. This guide is designed to show the reader how to safely replace the USB outlet to restore proper function to your Numark N4 without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Neye ihtiyacın var
Turn the Numark N4 over so that the bottom panel is facing upwards.
Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
4 farklı kişi bu kılavuzu tamamladı.
