Ana içeriğe geç
Numark N4 USB Port Replacement
Neye ihtiyacın var
    1. Numark N4 USB Port Replacement, Numark N4 Disassembly: adım 1, 1 resimden 1.
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Numark N4 USB Port Replacement: adım 2, 1 resimden 1.
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      FixBot'a Sor
      Yorum Ekle
    3. Numark N4 USB Port Replacement: adım 3, 1 resimden 1.
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      FixBot'a Sor
      Yorum Ekle
    4. Numark N4 USB Port Replacement: adım 4, 1 resimden 1.
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      FixBot'a Sor
      Yorum Ekle
    5. Numark N4 USB Port Replacement: adım 5, 1 resimden 1.
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      FixBot'a Sor
      Yorum Ekle
    6. Numark N4 USB Port Replacement: adım 6, 1 resimden 1.
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      FixBot'a Sor
      Yorum Ekle
    1. Numark N4 USB Port Replacement, USB Port: adım 7, 1 resimden 1.
      • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Numark N4 USB Port Replacement: adım 8, 1 resimden 1.
      • Carefully remove the circuit board from its housing.
      FixBot'a Sor
      Yorum Ekle
    3. Numark N4 USB Port Replacement: adım 9, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Erik Charlton
900 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G11, Cagle Fall 2017 USF Tampa, Team S13-G11, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G11
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
i we like to get the new board of dis numark n4
daniel benson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 3,069
