Ana içeriğe geç
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: adım 1, 1 resimden 1.
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: adım 2, 1 resimden 1.
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: adım 3, 1 resimden 1.
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: adım 4, 1 resimden 1.
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: adım 5, 1 resimden 1.
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: adım 6, 2 resimden 1. Numark TT1600 Belt Drive Replacement: adım 6, 2 resimden 2.
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: adım 7, 1 resimden 1.
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Nikolai
254 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G14
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 6,618
