Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Numark TT1600 Tone Arm Replacement
Neye ihtiyacın var
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: adım 1, 2 resimden 1. Numark TT1600 Tone Arm Replacement, Tone Arm: adım 1, 2 resimden 2.
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: adım 3, 3 resimden 1. Numark TT1600 Tone Arm Replacement: adım 3, 3 resimden 2. Numark TT1600 Tone Arm Replacement: adım 3, 3 resimden 3.
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: adım 4, 3 resimden 1. Numark TT1600 Tone Arm Replacement: adım 4, 3 resimden 2. Numark TT1600 Tone Arm Replacement: adım 4, 3 resimden 3.
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: adım 5, 2 resimden 1. Numark TT1600 Tone Arm Replacement: adım 5, 2 resimden 2.
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: adım 6, 3 resimden 1. Numark TT1600 Tone Arm Replacement: adım 6, 3 resimden 2. Numark TT1600 Tone Arm Replacement: adım 6, 3 resimden 3.
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: adım 7, 2 resimden 1. Numark TT1600 Tone Arm Replacement: adım 7, 2 resimden 2.
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: adım 8, 1 resimden 1.
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: adım 9, 3 resimden 1. Numark TT1600 Tone Arm Replacement: adım 9, 3 resimden 2. Numark TT1600 Tone Arm Replacement: adım 9, 3 resimden 3.
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: adım 10, 3 resimden 1. Numark TT1600 Tone Arm Replacement: adım 10, 3 resimden 2. Numark TT1600 Tone Arm Replacement: adım 10, 3 resimden 3.
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nikolai
254 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G14
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 8,211
