Ana içeriğe geç
Nvidia Shield Battery Assembly Replacement
Neye ihtiyacın var
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: adım 1, 3 resimden 1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: adım 1, 3 resimden 2. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: adım 1, 3 resimden 3.
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    FixBot'a Sor
    Yorum Ekle
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: adım 2, 2 resimden 1. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: adım 2, 2 resimden 2.
    • The green grill is not screwed in so it can be pulled right out.
    FixBot'a Sor
    Yorum Ekle
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: adım 3, 3 resimden 1. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: adım 3, 3 resimden 2. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: adım 3, 3 resimden 3.
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
    FixBot'a Sor
    Yorum Ekle
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: adım 4, 1 resimden 1.
    • Pull the battery apparatus out once all cables are removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Andrew Barbanera
376 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G1
4 Üyeler
18 adet Kılavuz yazıldı
6Kılavuz Yorumları
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Yanıt Paylaş
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Yanıt Paylaş
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Yanıt Paylaş
hi! how is this holding up nowadays? i found my old nvidia shield in storage recently and the batteries are completely dead ;;
Canvas - Yanıt Paylaş
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 82
Her zaman: 7,646
