Giriş
The Nvidia Controller Mother Board may fail due to wires becoming undone and the rumble motor not working.
Neye ihtiyacın var
Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
Gently lift the motherboard from the controller housing.
After removing the triggers, your motherboard is completely separate and ready to be replaced.
Sonuç
Your motherboard is ready to be replaced.
