Ana içeriğe geç
Nvidia Shield Pro Android TV Controller Triggers Replacement
Neye ihtiyacın var
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: adım 1, 3 resimden 1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: adım 1, 3 resimden 2. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: adım 1, 3 resimden 3.
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 2, 1 resimden 1.
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 3, 2 resimden 1. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 3, 2 resimden 2.
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 4, 2 resimden 1. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 4, 2 resimden 2.
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 5, 2 resimden 1. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 5, 2 resimden 2.
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: adım 6, 3 resimden 1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: adım 6, 3 resimden 2. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: adım 6, 3 resimden 3.
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 7, 3 resimden 1. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 7, 3 resimden 2. Nvidia Shield Pro Android TV Controller Triggers Replacement: adım 7, 3 resimden 3.
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
Sonuç
1Rehber Yorum
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 356
