Ana içeriğe geç
Nvidia Shield Pro Android TV I/O Board Replacement
Neye ihtiyacın var
  1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: adım 1, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: adım 2, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: adım 2, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
  3. Nvidia Shield Pro Android TV I/O Board Replacement: adım 3, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 3, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement: adım 3, 3 resimden 3.
    • Detach the pack of wires by pulling it away from the socket.
  4. Nvidia Shield Pro Android TV I/O Board Replacement: adım 4, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 4, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement: adım 4, 3 resimden 3.
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
    These are horrible, potentially damaging instructions. DO NOT try removing the ribbon cable without unlocking the connector first. Gently lift the black, plastic tab on the end by flipping it up toward the white ribbon cable connector. It will hinge all the way up until it moves freely. This is not pictured above, all three images show the tab in the locked position.
    Now the ribbon cable should easily slide out of the connector without any additional force. If it doesn't, the tab is likely not lifted up all the way.
    Be very careful with the ribbon cable and do not bend it. Simply applying force until it slips out as suggested above could cause irreversible damage.
    J J - Yanıt
  5. Nvidia Shield Pro Android TV I/O Board Replacement: adım 5, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 5, 2 resimden 2.
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
  6. Nvidia Shield Pro Android TV I/O Board Replacement: adım 6, 1 resimden 1.
    • Gently pull the hard drive out of the device.
  7. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: adım 7, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: adım 7, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: adım 7, 3 resimden 3.
    • Detach the brown side of the connector from the I/O board by pulling it upward.
    • Remove the screw from the silver plate using a T6 Torx screwdriver.
    • Put the cable aside after removing it.
  8. Nvidia Shield Pro Android TV I/O Board Replacement: adım 8, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 8, 2 resimden 2.
    • Detach the small bundle of black wires from the I/O board by gently pulling upward.
    • Be very gentle because the wires are very fragile.
  9. Nvidia Shield Pro Android TV I/O Board Replacement: adım 9, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 9, 2 resimden 2.
    • Remove the three T6 Torx screws from the I/O board.
  10. Nvidia Shield Pro Android TV I/O Board Replacement: adım 10, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 10, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement: adım 10, 3 resimden 3.
    • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
  11. Nvidia Shield Pro Android TV I/O Board Replacement: adım 11, 1 resimden 1.
    • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Jimmy Chen
639 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S18G2
4 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - Yanıt
Aniyone managed to get a source for this part, The IO board
Yoda Mann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 96
Her zaman: 5,473
