Ana içeriğe geç
Nvidia Shield Tablet K1 Battery Replacement
Neye ihtiyacın var
    1. Nvidia Shield Tablet K1 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
      • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
      FixBot'a Sor
      Yorum Ekle
    2. Nvidia Shield Tablet K1 Battery Replacement: adım 2, 2 resimden 1. Nvidia Shield Tablet K1 Battery Replacement: adım 2, 2 resimden 2.
      • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
      • Continue lifting up the panel all the way around the edges of the tablet.
      • Once all of the panel clips are unfastened, gently remove the back panel.
      FixBot'a Sor
      Yorum Ekle
    1. Nvidia Shield Tablet K1 Battery Replacement, Battery: adım 3, 2 resimden 1. Nvidia Shield Tablet K1 Battery Replacement, Battery: adım 3, 2 resimden 2.
      • The battery is heavily glued down so you will need to apply force while also exercising caution to not damage the rest of the device.
      • Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
      FixBot'a Sor
      Yorum Ekle
    2. Nvidia Shield Tablet K1 Battery Replacement: adım 4, 3 resimden 1. Nvidia Shield Tablet K1 Battery Replacement: adım 4, 3 resimden 2. Nvidia Shield Tablet K1 Battery Replacement: adım 4, 3 resimden 3.
      • Once you have the blue plastic opening tool underneath the battery, work the tool around the edges of the battery similar to the technique used for the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. Nvidia Shield Tablet K1 Battery Replacement: adım 5, 1 resimden 1.
      • When the battery seems loose enough, use the blue plastic opening tool to lift the battery from the device.
      • The battery has four wires connecting it to the device. Be careful not to damage these wires while removing the battery.
      FixBot'a Sor
      Yorum Ekle
    4. Nvidia Shield Tablet K1 Battery Replacement: adım 6, 3 resimden 1. Nvidia Shield Tablet K1 Battery Replacement: adım 6, 3 resimden 2. Nvidia Shield Tablet K1 Battery Replacement: adım 6, 3 resimden 3.
      • The wires to the battery are soldered to the motherboard. You may also check the soldering techniques guide for additional tips on soldering.
      • If your device's wiring doesn't exactly match these photos, snap a picture or make a note of what color wire goes to which contact on the motherboard before you detach them. (A mis-wired battery could cause electrical shorts and ruin the tablet for good.)
      • Using a soldering iron, desolder the four wires from the motherboard.
      • Once the wires are free from the motherboard, your battery should be free to remove from your device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
James Upchurch
658 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-7, Cagle Spring 2016 USF Tampa, Team 7-7, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S7G7
3 Üyeler
9 adet Kılavuz yazıldı
7Kılavuz Yorumları
Hello! Can anyone suggest a specific battery for K1 model ? Also the new battery comes with it's own wires as it is shown on Step5 ?
Hablando - Yanıt Paylaş
Quelqu'un peut-il proposer une batterie spécifique pour le modèle K1 s'il vous plait ?
Tony 06 - Yanıt Paylaş
Cannot find a replacement battery anywhere, any information would be appreciated.
Thanks!
Carl
cgarrand1 - Yanıt Paylaş
Here: to aliexpress
I just happened to be looking because my battery life is atrocious. And here's the forum where I found it. They have other links too if you want to try them out.
XDA dev
Nathaniel Phillips - Yanıt Paylaş
I just happened to be looking into this myself. I found a forum with many links that can be found by searching “Finding Replacement Battery in 2017?” . The thread is on XDA-developers.com. This is a link that works: on de.aliexpress.com
Good luck. As there is no convincing upgrade from the Shield K1, I might do this too. Other people noted that you need the little PCB attached to the original battery to solder it onto the bare replacement battery.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 86
Her zaman: 43,865
