Ana içeriğe geç
Oculus Rift Control Box Motherboard Replacement
Neye ihtiyacın var
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: adım 1, 3 resimden 1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: adım 1, 3 resimden 2. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: adım 1, 3 resimden 3.
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
    FixBot'a Sor
    Yorum Ekle
  2. Oculus Rift Control Box Motherboard Replacement: adım 2, 3 resimden 1. Oculus Rift Control Box Motherboard Replacement: adım 2, 3 resimden 2. Oculus Rift Control Box Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
    FixBot'a Sor
    Yorum Ekle
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: adım 3, 3 resimden 1. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: adım 3, 3 resimden 2. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: adım 3, 3 resimden 3.
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
    FixBot'a Sor
    Yorum Ekle
  4. Oculus Rift Control Box Motherboard Replacement: adım 4, 3 resimden 1. Oculus Rift Control Box Motherboard Replacement: adım 4, 3 resimden 2. Oculus Rift Control Box Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Audrey Chan
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 1,545
