Ana içeriğe geç
Olympus Camedia D560 Rear Panel Control Buttons Replacement
Neye ihtiyacın var
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: adım 1, 2 resimden 1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: adım 1, 2 resimden 2.
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 2, 2 resimden 1. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 2, 2 resimden 2.
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 3, 3 resimden 1. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 3, 3 resimden 2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 3, 3 resimden 3.
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 4, 3 resimden 1. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 4, 3 resimden 2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 4, 3 resimden 3.
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 5, 3 resimden 1. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 5, 3 resimden 2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: adım 5, 3 resimden 3.
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
Sonuç
Bir başkası bu kılavuzu tamamladı.
GradStudents2011
21 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 982
