Ana içeriğe geç
Olympus FE-170 Lens Replacement
Neye ihtiyacın var
  1. Olympus FE-170 Lens Replacement, Casing: adım 1, 2 resimden 1. Olympus FE-170 Lens Replacement, Casing: adım 1, 2 resimden 2.
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
    FixBot'a Sor
    Yorum Ekle
  2. Olympus FE-170 Lens Replacement: adım 2, 2 resimden 1. Olympus FE-170 Lens Replacement: adım 2, 2 resimden 2.
    • Open the battery compartment and remove the 2 screws in the top of the opening.
    FixBot'a Sor
    Yorum Ekle
  3. Olympus FE-170 Lens Replacement: adım 3, 2 resimden 1. Olympus FE-170 Lens Replacement: adım 3, 2 resimden 2.
    • Remove the 2 exposed screws on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Olympus FE-170 Lens Replacement: adım 4, 1 resimden 1.
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
    FixBot'a Sor
    Yorum Ekle
  5. Olympus FE-170 Lens Replacement: adım 5, 1 resimden 1.
    • Uncover the video cable port on the side of the camera and remove the screw
    FixBot'a Sor
    Yorum Ekle
  6. Olympus FE-170 Lens Replacement: adım 6, 2 resimden 1. Olympus FE-170 Lens Replacement: adım 6, 2 resimden 2.
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  7. Olympus FE-170 Lens Replacement: adım 7, 2 resimden 1. Olympus FE-170 Lens Replacement: adım 7, 2 resimden 2.
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
    FixBot'a Sor
    Yorum Ekle
  8. Olympus FE-170 Lens Replacement: adım 8, 2 resimden 1. Olympus FE-170 Lens Replacement: adım 8, 2 resimden 2.
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
    FixBot'a Sor
    Yorum Ekle
  9. Olympus FE-170 Lens Replacement, Motherboard: adım 9, 3 resimden 1. Olympus FE-170 Lens Replacement, Motherboard: adım 9, 3 resimden 2. Olympus FE-170 Lens Replacement, Motherboard: adım 9, 3 resimden 3.
    • Remove the three screws holding the outer circuit board in place.
    FixBot'a Sor
    Yorum Ekle
  10. Olympus FE-170 Lens Replacement: adım 10, 2 resimden 1. Olympus FE-170 Lens Replacement: adım 10, 2 resimden 2.
    • Use the spudger or your fingers to remove the outer circuit board from the camera.
    FixBot'a Sor
    Yorum Ekle
  11. Olympus FE-170 Lens Replacement: adım 11, 3 resimden 1. Olympus FE-170 Lens Replacement: adım 11, 3 resimden 2. Olympus FE-170 Lens Replacement: adım 11, 3 resimden 3.
    • Use the spudger to pull the plastic tabs shown off of the motherboard.
    • Gently pull the plastic piece off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. Olympus FE-170 Lens Replacement: adım 12, 3 resimden 1. Olympus FE-170 Lens Replacement: adım 12, 3 resimden 2. Olympus FE-170 Lens Replacement: adım 12, 3 resimden 3.
    • Remove the screws shown using the 00 philips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  13. Olympus FE-170 Lens Replacement: adım 13, 3 resimden 1. Olympus FE-170 Lens Replacement: adım 13, 3 resimden 2. Olympus FE-170 Lens Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the pointed end of the spudger to release the ribbon cable clasp.
    • Remove the ribbon cable from the port using the tweezers.
    FixBot'a Sor
    Yorum Ekle
  14. Olympus FE-170 Lens Replacement: adım 14, 1 resimden 1.
    • Use the tweezers to remove the ribbon cable near the shutter button.
    FixBot'a Sor
    Yorum Ekle
  15. Olympus FE-170 Lens Replacement: adım 15, 1 resimden 1.
    • Next unsolder the connections shown.
    • See our soldering guide for help on how to unsolder
    • Soldering irons are hot, and will also heat the connection wire. Using the tweezers will protect your fingers from the heat.
    FixBot'a Sor
    Yorum Ekle
  16. Olympus FE-170 Lens Replacement: adım 16, 3 resimden 1. Olympus FE-170 Lens Replacement: adım 16, 3 resimden 2. Olympus FE-170 Lens Replacement: adım 16, 3 resimden 3.
    • Gently pull the motherboard (from the bottom first) away from the device.
    FixBot'a Sor
    Yorum Ekle
  17. Olympus FE-170 Lens Replacement, Lens: adım 17, 3 resimden 1. Olympus FE-170 Lens Replacement, Lens: adım 17, 3 resimden 2. Olympus FE-170 Lens Replacement, Lens: adım 17, 3 resimden 3.
    • Remove the 3 screws holding the lens assembly in place.
    FixBot'a Sor
    Yorum Ekle
  18. Olympus FE-170 Lens Replacement: adım 18, 3 resimden 1. Olympus FE-170 Lens Replacement: adım 18, 3 resimden 2. Olympus FE-170 Lens Replacement: adım 18, 3 resimden 3.
    • Gently remove the lens assembly by pulling on the top of the assembly first, then removing from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
CCrane
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 1,187
