Ana içeriğe geç
Olympus FE-170 Motherboard Replacement
Neye ihtiyacın var
  1. Olympus FE-170 Motherboard Replacement, Casing: adım 1, 2 resimden 1. Olympus FE-170 Motherboard Replacement, Casing: adım 1, 2 resimden 2.
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Olympus FE-170 Motherboard Replacement: adım 2, 2 resimden 1. Olympus FE-170 Motherboard Replacement: adım 2, 2 resimden 2.
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Olympus FE-170 Motherboard Replacement: adım 3, 2 resimden 1. Olympus FE-170 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Olympus FE-170 Motherboard Replacement: adım 4, 1 resimden 1.
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Olympus FE-170 Motherboard Replacement: adım 5, 1 resimden 1.
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Olympus FE-170 Motherboard Replacement: adım 6, 2 resimden 1. Olympus FE-170 Motherboard Replacement: adım 6, 2 resimden 2.
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Olympus FE-170 Motherboard Replacement: adım 7, 2 resimden 1. Olympus FE-170 Motherboard Replacement: adım 7, 2 resimden 2.
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Olympus FE-170 Motherboard Replacement: adım 8, 2 resimden 1. Olympus FE-170 Motherboard Replacement: adım 8, 2 resimden 2.
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
  9. Olympus FE-170 Motherboard Replacement, Motherboard: adım 9, 3 resimden 1. Olympus FE-170 Motherboard Replacement, Motherboard: adım 9, 3 resimden 2. Olympus FE-170 Motherboard Replacement, Motherboard: adım 9, 3 resimden 3.
    • Remove the three screws holding the outer circuit board in place.
  10. Olympus FE-170 Motherboard Replacement: adım 10, 2 resimden 1. Olympus FE-170 Motherboard Replacement: adım 10, 2 resimden 2.
    • Use the spudger or your fingers to remove the outer circuit board from the camera.
  11. Olympus FE-170 Motherboard Replacement: adım 11, 3 resimden 1. Olympus FE-170 Motherboard Replacement: adım 11, 3 resimden 2. Olympus FE-170 Motherboard Replacement: adım 11, 3 resimden 3.
    • Use the spudger to pull the plastic tabs shown off of the motherboard.
    • Gently pull the plastic piece off of the motherboard.
  12. Olympus FE-170 Motherboard Replacement: adım 12, 3 resimden 1. Olympus FE-170 Motherboard Replacement: adım 12, 3 resimden 2. Olympus FE-170 Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the screws shown using the 00 philips screwdriver.
  13. Olympus FE-170 Motherboard Replacement: adım 13, 3 resimden 1. Olympus FE-170 Motherboard Replacement: adım 13, 3 resimden 2. Olympus FE-170 Motherboard Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the pointed end of the spudger to release the ribbon cable clasp.
    • Remove the ribbon cable from the port using the tweezers.
  14. Olympus FE-170 Motherboard Replacement: adım 14, 1 resimden 1.
    • Use the tweezers to remove the ribbon cable near the shutter button.
  15. Olympus FE-170 Motherboard Replacement: adım 15, 1 resimden 1.
    • Next unsolder the connections shown.
    • See our soldering guide for help on how to unsolder
    • Soldering irons are hot, and will also heat the connection wire. Using the tweezers will protect your fingers from the heat.
  16. Olympus FE-170 Motherboard Replacement: adım 16, 3 resimden 1. Olympus FE-170 Motherboard Replacement: adım 16, 3 resimden 2. Olympus FE-170 Motherboard Replacement: adım 16, 3 resimden 3.
    • Gently pull the motherboard (from the bottom first) away from the device.
Sonuç
Tyler Hartwig
337 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 456
