Olympus Stylus 725 SW LCD Screen Replacement
Giriş
1. adıma gitThis guide provides instructions for replacing a broken LCD screen on the Olympus Stylus 725.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
Remove the screws in the back panel using a Phillips #00 screwdriver.
Detach the ribbon cables that connect the LCD to the back panel of the camera.
Bir başkası bu kılavuzu tamamladı.
