Giriş
In this guide, we will walk through the steps necessary to replacing the congestion-sensing antenna.
Neye ihtiyacın var
While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
Remove the wire connection to the antenna by soldering it off.
For help with soldering and de-soldering check out the iFixit Soldering Guide
3 farklı kişi bu kılavuzu tamamladı.
