Giriş
If your OneLink Safe and Sound won't connect to your phone it could be due to a malfunctioning Bluetooth module. Before replacing the Bluetooth module, please refer to the OneLink Safe and Sound Troubleshooting page for other fixes to this problem.
Neye ihtiyacın var
Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
Remove plastic rim.
Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
