Ana içeriğe geç
OnePlus 5T Back Cover Replacement
Neye ihtiyacın var
    1. OnePlus 5T Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. OnePlus 5T Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
      • Before you begin, switch off your phone.
      • Remove the SIM card tray.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 5T Back Cover Replacement: adım 2, 1 resimden 1.
      • Remove the two Torx T2 screws (2.5 mm length).
      • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 5T Back Cover Replacement: adım 3, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 3, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 3, 3 resimden 3.
      • Insert an opening tool between the display and the backcover at the bottom end of the phone.
      • Use the opening tool to create a gap between back cover and display.
      • Insert an opening pick in the gap you created with the opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 5T Back Cover Replacement: adım 4, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 4, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 4, 3 resimden 3.
      • Slide the opening pick to the bottom right corner of the phone.
      • Insert a second opening pick and slide it to the bottom left corner of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. OnePlus 5T Back Cover Replacement: adım 5, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 5, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 5, 3 resimden 3.
      • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
      FixBot'a Sor
      Yorum Ekle
    6. OnePlus 5T Back Cover Replacement: adım 6, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 6, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 6, 3 resimden 3.
      • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
      FixBot'a Sor
      Yorum Ekle
    7. OnePlus 5T Back Cover Replacement: adım 7, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 7, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 7, 3 resimden 3.
      • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
      • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
      FixBot'a Sor
      Yorum Ekle
    8. OnePlus 5T Back Cover Replacement: adım 8, 2 resimden 1. OnePlus 5T Back Cover Replacement: adım 8, 2 resimden 2.
      • Use a spudger to pry up and disconnect the fingerprint flex cable.
      FixBot'a Sor
      Yorum Ekle
    9. OnePlus 5T Back Cover Replacement: adım 9, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 9, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 9, 3 resimden 3.
      • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
      FixBot'a Sor
      Yorum Ekle
    10. OnePlus 5T Back Cover Replacement: adım 10, 3 resimden 1. OnePlus 5T Back Cover Replacement: adım 10, 3 resimden 2. OnePlus 5T Back Cover Replacement: adım 10, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
      FixBot'a Sor
      Yorum Ekle
    11. OnePlus 5T Back Cover Replacement: adım 11, 2 resimden 1. OnePlus 5T Back Cover Replacement: adım 11, 2 resimden 2.
      • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
      FixBot'a Sor
      Yorum Ekle
    12. OnePlus 5T Back Cover Replacement: adım 12, 2 resimden 1. OnePlus 5T Back Cover Replacement: adım 12, 2 resimden 2.
      • Remove the backcover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
6 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
263.018 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
65.378 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 82
Her zaman: 4,419
