Ana içeriğe geç
OnePlus 5T Speaker Replacement
  1. OnePlus 5T Speaker Replacement, Back Cover: adım 1, 2 resimden 1. OnePlus 5T Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before you begin, switch off your phone.
    • Remove the SIM card tray.
  2. OnePlus 5T Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the two Torx T2 screws (2.5 mm length).
    • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
  3. OnePlus 5T Speaker Replacement: adım 3, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 3, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 3, 3 resimden 3.
    • Insert an opening tool between the display and the backcover at the bottom end of the phone.
    • Use the opening tool to create a gap between back cover and display.
    • Insert an opening pick in the gap you created with the opening tool.
  4. OnePlus 5T Speaker Replacement: adım 4, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 4, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 4, 3 resimden 3.
    • Slide the opening pick to the bottom right corner of the phone.
    • Insert a second opening pick and slide it to the bottom left corner of the phone.
  5. OnePlus 5T Speaker Replacement: adım 5, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 5, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 5, 3 resimden 3.
    • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
  6. OnePlus 5T Speaker Replacement: adım 6, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 6, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 6, 3 resimden 3.
    • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
  7. OnePlus 5T Speaker Replacement: adım 7, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 7, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 7, 3 resimden 3.
    • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
    • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
  8. OnePlus 5T Speaker Replacement: adım 8, 2 resimden 1. OnePlus 5T Speaker Replacement: adım 8, 2 resimden 2.
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
  9. OnePlus 5T Speaker Replacement: adım 9, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 9, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 9, 3 resimden 3.
    • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
  10. OnePlus 5T Speaker Replacement: adım 10, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 10, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 10, 3 resimden 3.
    • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
  11. OnePlus 5T Speaker Replacement: adım 11, 2 resimden 1. OnePlus 5T Speaker Replacement: adım 11, 2 resimden 2.
    • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
  12. OnePlus 5T Speaker Replacement: adım 12, 2 resimden 1. OnePlus 5T Speaker Replacement: adım 12, 2 resimden 2.
    • Remove the backcover.
  13. OnePlus 5T Speaker Replacement, Battery Disconnect: adım 13, 2 resimden 1. OnePlus 5T Speaker Replacement, Battery Disconnect: adım 13, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery flex cable.
  14. OnePlus 5T Speaker Replacement, Speaker: adım 14, 1 resimden 1.
    • Remove the six Phillips #00 screws (2.9 mm length).
  15. OnePlus 5T Speaker Replacement: adım 15, 3 resimden 1. OnePlus 5T Speaker Replacement: adım 15, 3 resimden 2. OnePlus 5T Speaker Replacement: adım 15, 3 resimden 3.
    • Slide an opening pick underneath the left side of the speaker.
    • Use the opening pick to pry the speaker up and out of its recess.
  16. OnePlus 5T Speaker Replacement: adım 16, 2 resimden 1. OnePlus 5T Speaker Replacement: adım 16, 2 resimden 2.
    • Remove the speaker.
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
165.878 İtibar
661 adet Kılavuz yazıldı
iFixit iFixit üyesi
Community
137 Üyeler
17.053 adet Kılavuz yazıldı
One Comment
Following water damage the loudspeaker stopped working. I changed it out (twice) and the flex cable but still not working. Any ideas?
Daryl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 1,981
