Ana içeriğe geç
OnePlus 6 Lower Frame Replacement
Neye ihtiyacın var
  1. OnePlus 6 Lower Frame Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    FixBot'a Sor
    Yorum Ekle
  2. OnePlus 6 Lower Frame Replacement: adım 2, 2 resimden 1. OnePlus 6 Lower Frame Replacement: adım 2, 2 resimden 2.
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  3. OnePlus 6 Lower Frame Replacement: adım 3, 2 resimden 1. OnePlus 6 Lower Frame Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    FixBot'a Sor
    Yorum Ekle
  4. OnePlus 6 Lower Frame Replacement, Lower Frame: adım 4, 2 resimden 1. OnePlus 6 Lower Frame Replacement, Lower Frame: adım 4, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the eight 3 mm screws from the lower frame.
    • Gently lift the lower panel up and out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mickenzie Thompson
373 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G3
5 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 1,065
