Ana içeriğe geç
OnePlus 6 Rear Camera Replacement
Neye ihtiyacın var
    1. OnePlus 6 Rear Camera Replacement, Back Panel: adım 1, 1 resimden 1.
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 6 Rear Camera Replacement: adım 2, 2 resimden 1. OnePlus 6 Rear Camera Replacement: adım 2, 2 resimden 2.
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 6 Rear Camera Replacement: adım 3, 2 resimden 1. OnePlus 6 Rear Camera Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6 Rear Camera Replacement, Battery: adım 4, 2 resimden 1. OnePlus 6 Rear Camera Replacement, Battery: adım 4, 2 resimden 2.
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6 Rear Camera Replacement, Fingerprint sensor: adım 5, 2 resimden 1. OnePlus 6 Rear Camera Replacement, Fingerprint sensor: adım 5, 2 resimden 2.
      • The midframe is made of plastic and located above the battery space.
      • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
      • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
      • Lift the bottom of the mid frame directly up and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6 Rear Camera Replacement, Motherboard: adım 6, 1 resimden 1.
      • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 6 Rear Camera Replacement: adım 7, 2 resimden 1. OnePlus 6 Rear Camera Replacement: adım 7, 2 resimden 2.
      • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
      • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
      • The cameras should lift up with the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6 Rear Camera Replacement, Rear Camera: adım 8, 2 resimden 1. OnePlus 6 Rear Camera Replacement, Rear Camera: adım 8, 2 resimden 2.
      • Lift up on the small tabs connecting the cameras to the motherboard to disconnect them.
      • Push on the lens side of the cameras and remove them from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Hunter Brown
118 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G3
5 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 1,753
